Removing the carbs
Ginger Ninja
Removing the carbs
Post by Ginger Ninja »
hi all
just joined the club. nice to meet u all
i currently own a zxr400 l3. i have had it restricted using washers placed between the carbs and the inlets. i was wondering if anyone could tell me how to remove the carbs for i wish to derestrict it??
i have read the article on carb balancing so i know how to get to the carbs just don't know what else i need to do with the carbs to remove them.
thanks for reading. hope to here from u soon
the GINGER NINJA :smt003
Re: Removing the carbs
Glad to hear youve read some of the workshop section!
Once youve gotten to the carbs all you need to do is undo the round clips at the back by un-screwing them, you can see them here, its the screws that are pointing from left to right inbetween the block and carbs.
Once you have undone those, they should pull off, but if they are proving difficult push them down and then pull up while pulling back, be careful you dont go flying when they finally come off!
You should then just have the inlet rubbers left and if you look at them you will see something like this
All you need to do then is undo the allen bolts on the top and underneath the rubbers that hold them in place untill they come out, at which point the washers should also come out.
You shouldnt need to completely take the carbs off so you can leave all the relevant cables in place, assembly is reverse of dissasembly minus the washers :smt002
Any problems just give us a shout here and well put you straight.
RobB :smt001
P.S. If you have balancing gauges you may as well balance them while its all apart, itll run smoother and faster :smt002
Ginger Ninja
thanks alot for the info
i'll probably tackle it tomorrow. thanks again
GINJER NINJA
BANJO
My Bike: ZX4R NINJA
Post by BANJO »
hello rob the three screws that you have circle are they not the adjustment screws for the throttle butterflies
to take the carbs off you need to undo the 4 screws that are on the black rubber bit 2 facing right and 2 facing left
our have i miss read the question
regards
dean
yeah its not the circled ones. the ones that banjo pointed out. That pic was ready so used it. :smt001
why have it restricted then remove the restrictions??? :smt017
Ginger Ninja
had to but i got bored of them.
one more thing. if i remove the restrictors will i have any problems with compression, etc???
cheers
Ginger Ninja
Ginger Ninja wrote:hi all
no you just joined the forum, you have to pay to join the club :smt005
Ginger Ninja wrote:had to but i got bored of them.
cheers
Ginger Ninja
You wont have any problems at all mate, only thing it changes is the speed fuel and air goes in. Whip em out and enjoy the (saying in a Jeremy Clarkson style) POWERRRRRRRR!
masterofinsanity wrote:why have it restricted then remove the restrictions??? :smt017
i agree i never even bothered to get mine restricted :D
other the 750...120bhp inst that much more than 33 really is it..
