why is my radator fluid green?
kion
- My Bike: zxr400
Re: why is my radator fluid green?
cos you mic blue antifreeze with water and it goes green at the right mixture, could depend on what antifreeze has been used too, think there are a couple of types, some blue and some green.
kion
- My Bike: zxr400
oh thankgod, still gonna flush it when i get the time.
ride with pride
Yep, there is blue and green, dunno what the difference is apart from the colour.
something to do with the chemical content i think ones methanol glycol & the other is something else.the manual will tell you which you are supposed to use.but i guess some is better than none.something to do with the corrosion properties i think.
mines pink
its bad getting a collent leak but if i get one out side a gay bar, in tight leathers, leaking pink fluids all over the place i dout i'll get away with my anal verginity
zxr400 L5 handbook wrote:a permanent type of antifreeze is installed in the cooling system when shipped.It is coloured green and contains ethylene glycol.It is mixed at 50% and has a freezing point of -35 degrees C
