ZXR400 H Forks - problem - help please
Posted: Thu Sep 20, 2007 10:54 pm
Can anyone offer advice on the following ?
I have fitted a set of ZXR400 H model forks after fully refubishing them.
with the forks fitted with identical height of fork above the top yoke and the fork legs hanging i find that the front wheel spindle does not line up exactly from right leg to left leg and to allow the spindle to screw into the left leg insert i have to lift the bottom of the left leg by about 5mm ?
Is this normal that there is some misalignment ?
Should i just have the left leg under slight tension when i fit the spindle then refit the mudguard assembly although if i then remove the wheel spindle there will be a twist on the mudguard as the left leg drops.
I could have the left leg through the yokes slightly more than the right leg but surely this isnt right ?
Has anyone experienced this before ?
regards
Nick
07976 300123
regards
Nick
07976 300123
