I was riding a H1 model till we had a disagreement and i met the road at thirtyish. Hence the need for engine side casing, fairing, indicator, mirrors etc.
Footpeg hangers?
Dave
Footpeg hangers?
I need a part number for left foot peg hanger. Any ideas?
MJJ400
Cannot help with the part number I'm afraid, but if you ring up Cradley Kawasaki they could tell you - plus price/lead time etc.
I probably have most of the stuff you need in the garage though, as I am parting an H1. Mirrors are currently on eBay though, so best be quick if you need them.
Hope you are OK after your spill.
Martin.
Martin.
check out the microfiches they will give you the part numbers.
Dave, i have a H model left hand footrest hanger going spare. Incorrect purchase on ebay
Theres a number on it, which is 355011-1494.
Anyways, bad bit is it has a small crack around where the botton bolt tightens in. Otherwise just needs a quick clean, so great if ya want a quick fix to get her on the road till you can afford a decent one
. Ill try and get a pic for you if i can find some decent batteries for my digital camera
Only want a tenner for it plus a few quid postage to you.
If ya interested let me know, pm me
Pics for ya Dave.
http://www.bikepics.com/pictures/258527/
The crack in the bolt hole. Not sure of you can use Loctite metal glue to keep this from cracking more, but theres no flex when you try and twist it so i imagine its still pretty strong. Also i doubt if it will break more as when you apply weight to the peg its going to pivot around the top nut. I think just be careful when you tighten. Once again my contact details are above so if ya interested let me know
http://www.bikepics.com/pictures/258528/
Dave
I've "bitten the buttit" and paid out £45 for a footpeg hanger from LM Spares. Its quite pricy but for the added confidence it is worth the pennies.
Thanks for the offer RobB. I may take you up on it at a later date if i can get it welded cheaply so I can have a spare.
You may want to get it welded and stick it on e-bay yourself and make a few quid??
Thanks for the help.
Dave
Dave
