bit of a random one
Caz
My Bike: GSX-R600 K4
bit of a random one
Post by Caz »
Where can I buy M8 x 1.00 grub screws? needs to be about 20 - 25mm length.
I can find normal pitch - but fine seems to be hard to come by!
any ideas :smt017 :smt017
GSX-R600 K4
ZXR400 H2
Commuter: Gilera Runner 180SP
deviant
Re: bit of a random one
Post by deviant »
searching for "set screws" rather than "grub screws" might help.
quick search turned up somewhere selling M8 x 1.00 x 25mm as part of a selection box, but i've lost the page cos I'm crap. sorry.
doing anything interesting? or just a work related question?
Caz
Post by Caz »
deviant wrote:searching for "set screws" rather than "grub screws" might help.
thanks :) i must look harder :-) Problem is, im only after small volumes (ca 10 of assorted lengths)
M8 x 1.00 is a bit small for us to use here :-P an M18 OTOH is an entirely different matter ;-)
my better half has a K1200R and has managed to somehow loose the clutch lever adjusting screw. and BMW being BMW only supply it as a whole assembly costing about £36! So, I'm now on a mission to find a solution:-)
I've got M8 x 1.00 socket head, which fits just fine. Unfortunately the screw head touches the switch gear when the clutch lever is pulled in. Can cut the head down, but it wont look particularly neat.
So a grub screw would solve that problem.
typical to get these problems 2.5 days before we are off to the Nurbuirgring!
GSX-R600 K4
ZXR400 H2
deviant
Post by deviant »
I did eventually find that page again, but closer inspection of the photo revealed them to be hex head - sadly while grub screw does refer to a grub screw and nothing else, there seems to be all sorts of things called set screws. so no help to you.
and you always break your bike just before you need it - because you tend to work on your bike just before a big trip. My favourite was deciding to do an oil change on the GS before riding it back down to uni at the start of term. Stripped the drain hole thread. £25 job to get it helicoiled, but the fact it was an engine out job (no removable sump on the GS) meant I went back to Bath on the train and spent the whole term without a bike before finally having time to sort it during the next holidays.
The Pole
Post by The Pole »
try here.
http://www.emkaysupplies.co.uk/catalogue.htm
although would have thought any reputable tools company would be able to supply.
or here
http://www.cromwell.co.uk/quicksearch
Cromwell are good. if there is one local just walk in and they may even just give you one.....er i mean er a set screw...
When one lives in a world full of madmen, one should train as a maniac.
Caz
Post by Caz »
The Pole wrote:try here.
or here
Thanks - I can find plenty of M8 x 1.25 grub screws or set screws whichever you prefer to call them :-P
But finding an M8 x 1.00 is proving slightly more difficult! I have a box of M8 x 1.00 cap screws at home - and they fit, i just want a grub screw to make it pretty :P
I'll just have to keep on looking
GSX-R600 K4
ZXR400 H2
The Pole
Post by The Pole »
Couldnt you just bang one in a soft jaw vice and take the .25 of the end you wont see? or am i missing something else?
Caz
Post by Caz »
The Pole wrote:Couldnt you just bang one in a soft jaw vice and take the .25 of the end you wont see? or am i missing something else?
the 1.00 and 1.25 refer to the pitch of the thread, not the length.
I'm after a fine thread one
GSX-R600 K4
ZXR400 H2
deviant
Post by deviant »
Caz...bored at work so had another look.
http://www.kellysearch.com/gb-company-80084546.html
note the words "Metric Fine Socket Capscrews" and "can deliver goods, via our carriers, next day to most parts of the U.K."
hope this helps.
Dave
i'll have a look what pitch ours are tommorrow at work caz
Caz
Post by Caz »
masterofinsanity wrote:i'll have a look what pitch ours are tommorrow at work caz
Cheers :smt003
GSX-R600 K4
ZXR400 H2
how do you know what the pitch is? :smt017
deviant
Post by deviant »
either look at what it says on the box, find a thread gauge, or see if it fits into caz's bloke's bike!
mmmmmmmthese aint in a box, we aint got a thread gauge so i guess if isend some off and they dont fit nowt lost then??
deviant
Post by deviant »
i think they are already at the 'ring. so presumably must have found a solution.
