oxford optimiser causing problems?
stumpy
Post by stumpy »
just wondering, can an oxford optimiser damage any of the charging/electric circuit on my zxr. i connect it to my zxr every time it is parked in garage to keep battery topped up but since i started using it the battery is going flat wen bike is out on a run. it does not always go flat, but will suddenly just not charge, even wen its been on a long run. did 80 miles last week in one run and then turned bike off, tried to restart it but it was totally flat.bike runs perfect once one of my mates as stopped moaning and gives me a push to bump start it. think this could be the regulator/rectifier? i am getting 13.5-14.5 volts at battery wen i checked it with bike running so could it be an intermittent fault? or the battery?or the alternater?
Re: oxford optimiser causing problems?
dont your optimiser tell you how the battery is m8?...
also are you sure its not this hot starting problem?
could be the hot starting problem, what about earth straps? could be loose or corroded.
stumpy
Post by stumpy »
optimiser says battery ok. but after running .i try and start it and i get ignition lights but it mite turn over once and then stop.bump starts really easy and runs fine then
stumpy
Post by stumpy »
wen i press the starter it it mite turn once then it just 'click'
similar problems i was having and my earth strap had corroded so a quick clean up with wire wool and all sorted.
stumpy
Post by stumpy »
cheers. was going to go out and buy a rectifier but wil check earth first. will post reply wen ive checked.
Northern ANdy
My Bike: Unique ZXR400
Post by Northern ANdy »
the voltage you state sounds healthy, as long as its not an intermitten fault as you say. Does sound like its not getting/holding a charge though. How old is the battery.
Andy
stumpy
Post by stumpy »
battery is about 18 month old. just looked at it, optimiser says its charged and ok but wen i try to start bike it turns over for about 3 seconds and then shows a flat battery on volt meter. before i try and start it , battery shows 12.5 volts, but as soon as ignition is on, it starts to drop.wen i try and start it ,it drops to 10.5 volts straight away. think it must be battery as wen its running, charging voltage is 13.5-14.2 volts.
Northern ANdy
I would start with the battery. Cheapish and easy to replace.
Andy
stumpy
Post by stumpy »
battery that was on was a cheap and nasty one.got a good quality one and put it on. hope to go out tomorrow on the bike (if it stops raining)to see if its ok. thanx to everybody for advice.
