Help, i have been told that i remove this gasket without too much trouble. I'm changing my head gasket and will remove it if it breaks but hope not to.
andy idea's
cheers
BASE GASKET
Caz
- My Bike: GSX-R600 K4
Re: BASE GASKET
erm.... I'm not entirely sure what you are asking here
GSX-R600 K4
ZXR400 H2
Commuter: Gilera Runner 180SP
ZXR400 H2
Re: BASE GASKET
you can safely rebuild the engine without the base gasket, it'll increase compression a tad, you will need to use high temp silicon sealant in place of it though.
if rebuilding with the base gasket its best to renew it rather than re-use it though, i guess you could use sealer but they aint expensive.
