I am having starting problems with my 400 L3. I would be grateful if someone could let me know the correct connections into the junction box under the seat.
It's the terminal for the starting side (Left Hand) there are two rows of 5 connections, if someone out there can let me know the wire colours on each terminal in the plug, starting on the top row left to right from above that would be graet.
Need to sort as she is booked on a track day late next week and she is struggling to start - no feed out to starter solonoid.
THANKS in Anticipation.
						Help required with Wiring on L3 model
Re: Help required with Wiring on L3 model
Hi there, mines and L3 also, so this should be very applicable!
I have from the top left facing the connector
black/red - green/yellow - red/yellow - white/dark green - lightgreen
and the bottom left facing the connector
yellow - green/black - brown/white - brown/red - brown/black
Hope that helps
p.s.
manuals are here if you need them
Hope that helps
p.s.
				andy427
Thanks for the info, looks like the starter side of the junction box is shorting.
Have to search ebay for replacement.
Thanks Again
Thanks Again
No probs
A few members here have had thier fuse boxes pack up, must be a bad batch out there.
- Jamz
 - My Bike: Kawasaki ZX9-R C2
I think I might have a fuse box that I was going to put on Ebay soon!
make me an offer and I'll find it out...
				andy427
Thanks for that have one coming but if no show will let you know.
