same ole restriction probs
hey i jus got myself a jap import 94 zxr and ive bin lookin ova the site for info bout it. im quite sure i need to get the 112mph restrictor out ill prob get the motrax converter. however i still think the bikes not as quick as it shud b in acceleration. ill be having a look for the restrictors in the carb and im also considering getting a uk spec cdi.
buuutt wot i wanna no is... does anyone know if they are restricted elsewhere ??
and
ive talked to a tuning company near mine in witham called total traction, they used to be kawasaki specialists. they said for £250+vat they will set it up and rollin road tune it and apparently theres stuff they can do to the inlet manifold to make it quicker etc.. does anyone know if this is true or worth doing???
and
mini hann
- SplaTZXR400
- My Bike: ZXR400
ye definately get a UK cdi, tho all this does is allows it rev up to like 14,500rpm instead of 10,000. but helps. erm, im unsure bout restrictions coz, i know there is a 33bhp restriction in the inlet manifold, washers. and apparently theres a speedo restricton, dunno how it works, something about pluggin in a black box to the speedo, i wonder if u disconnect it if u feel any difference? no there are things u can do, the simplist being things like k&n air filter, and there's trumpet things that go over the carb inlets claiming to gain 4bhp or so, some ppl use em, tho iv never seen any hard evidence as to there effect. they cost bout £40.
if ur having trouble accelerating, check simple things that effect power delivery, ie, mixtures correct, carbbalance, no flat spots, valve shims, inspect cam lobes aren't worn.
£250 + vat sounds alot for a simple dyno and tune. or is there more work involved, like dynojet kit, manifold stuff etc.
yeah im simons brother hes ok hes jus done his car lisence so he even more lethal. hes still got his zx7r looks v nice ill put some pics up tonight. thought id get myself a zxr400 as i liked his one when he had it. is his still floatin bout in ducati yellow????
and yeah i think theres a flat spot when i rev it quickly, ima give it a set of plugs and a service and all that stuff then ill see what the tuning involves with that company i think. im not sure but i think it already revs to 14k but its defo still i jap cdi cos i had a look ova day.
mini hann
Glad to here he's doing well, i have a 7R myself now. Send me the URL of the pics and ill put em up fior you, you wont be able to post em just yet.
You should get simon to give your zxr a run, he knows what it should be like. Also, run some redex through a tank of petrol, little bottle at Halfords for 99p will do a full tank. That should clean any crap out of your carbs, get em balanced too. Change the air filter, and as you said change the plugs
A UK CDI will sort out the speed restriction. The only other restriction is the 33bhp kit which is only fitted if your on a restricted licence. They sit in between the inlet rubbers and engine block. You can check for those by looking to see if there is a plate of some sort there, they usually overlap slightly, found a picture
How to remove 33bhp restrictors coming soon in the workshop section
yer si took the restrictors out of his i remeber him doin it. i dnt have any manuals cos he sold his but cnt be that hard lol. i would tell him to give it a run but hes in cheltnham i think, wit his gf.
I want to jus get the carbs balanced i recon cos total traction wanna do a load of other stuff so wot u recon i shud pay??
But neway heres the pics of mine and his bikes...
put ..
i132.photobucket . com
before each one
mine
his
he had the frame powdercoated last time he bought the bike down you can see in the pics its orangey green flip looks loverly.
put ..
before each one
mine
his
mini hann
You can see it through the carb yeah, either way you gotta take the air box off to see anything i think.
Just had a look, if the plates overlap the inlets like they do in that picture i posted, then you should be able to see them with just taking the tank off through the gap between the frame and the carbs themselves.
re revving problem
samuelhann wrote:yeah im simons brother hes ok hes jus done his car lisence so he even more lethal. hes still got his zx7r looks v nice ill put some pics up tonight. thought id get myself a zxr400 as i liked his one when he had it. is his still floatin bout in ducati yellow????
hi mate with regards to ur revving prob are you getting flat spots around 4000 rpm then again at about 6???? mine bogs down around here and according to the dyno guy near us he says there absolute shite below 6grand! i have a jap and the cdi is jap and i get 14500 rpm no probs but the fun dont really start till 9-10 k ish!!!
why is it that i cant keep my fingers outa the throttle??
