hi there been looking through the forum for a few hours now and trying to find out if the cams are set on TDC or set on fire ? can get everything to line up ok on TDC but cant turn the crank( trying not to be to cack handed as dont want to bend valves) can also get things lined up ok on fire and crank will turn. is it just that i need to put more force into crank when on TDC as it is working on 2 sets of valves. any help would be great am on a bit of a tight time frame though so hears hopping.
Thanks for any info
timming
tomzxr400
