noisey engine
ratbag56
My Bike: zxr400 / 636
noisey engine
Post by ratbag56 »
rode my bike to work yesterday and when i had come off the motor way and let the bike idle it sounded like somethin metal was lose inside the engine? the bike sounds perfect throu the whole rev range above 2000! the noise does not change when the clutch is pulled in , as it not the normal gearbox rattle? any ideas wot it needs? :smt017
Mate, im back from uni this week, if you wanna meet up at some point and want me to have a listen for you ill more than gladly have a look.
ratbag56
Post by ratbag56 »
can do its at work wit the engine out
Bloody hell your work is generous! Well let me know if you want me to listen when you get it back in frame. Sounds like it just might be the tensioner if its noisy below 2K.
ratbag56
Post by ratbag56 »
i know lol! i have found the problem my cam chain needs replacing as it has stretched and the tensoineer will not adjust it any more! so it was flapping around and the tensoiner was toucjing the case
