only fireing on 2 cyilinders
sole
is there anthing to look out for or is it just a case of running through all of the conectors the other 2 somtimes kick in and out
tomzxr400
first check that your getting a spark at the plug do this by takeing the plug out and tutching it to the engine (in a very dark room) then try to start it if you see the spark then you no its not the plug so more likly to be fuel!
if you arnt getting a spark then get a multi meter on the Coil and check that your getting 12Vs if not then work your way back checking every conector. if it is fireing on to then you should be getting a good earth but its always worth checking!
