Gear pedal
olionel
My Bike: 98' ZXR400
Gear pedal
Post by olionel »
Hi just bought a gear pedal assembly (including the footpeg and etc) from andy on this site. And Im trying to get the pedal, rather than changing the whole assembly, but I the allen key bolt does not want to move at all, so I started wondering is this thing all 1 piece? does that bolt come off to release the pedal ?
Thanks!
Oli
Northern ANdy
My Bike: Unique ZXR400
Post by Northern ANdy »
it does come off, but I cant remember if there is something you have to do at the back of it. Take a look
Andy
Yeah it deffo comes off, i got a feeling its got some thread lock stuff on it to stop it coming loose so that might be why. Its probably quite difficult trying to undo it on its own unless you can get it in a vice, failing that you could always fit it on the bike and try and undo it that way.
olionel
My Bike: 98' ZXR400
Post by olionel »
ye, I took my current one off the bike had a look as the assembly I bought is quite dirty and I couldnt see if that allen bolt was actually a seperate part. Yes it looks to be seperate, I dont have a vice (Im in uni so I keep moving house and dont have a set garage yet) anyway, Im off to get a generator cover gasket from a dealer tomorrow so might take both the assemblies and ask them nicely to loosen it for me.. shouldnt take them 5 minutes. Cheers anyways
Thanks!
Oli
heat it up a bit with a gas torch to loosen the loctite stuff
Rob is right there is thread lock in there holding that bolt
Bit of heat will help get it out.
In fact heat it up and then spray it with WD40 the thermal shock will work wonders.
Do not spray WD40 anywhere near your heat source just on the hot part
olionel
My Bike: 98' ZXR400
Post by olionel »
ok thanks a lot for the tips, Ill give it a go soon.
Thanks!
Oli
I wouldn't use a gas torch to heat it
Try a hot air gun
olionel
My Bike: 98' ZXR400
Post by olionel »
mmm I dont have a hot air gun... i think Im going to put it in a vive give it a try, if it doesnt work might try and heat it up a bit, isnt the thermal shock going to damage the metal tho? as its brittleness?
Thanks!
Oli
olionel wrote: isnt the thermal shock going to damage the metal tho? as its brittleness?
Not at the kind of temperatures that a hot air gun will produce.
If you used gas ans get it very (red hot) then yes maybe
If you do just clamp it in a vice use a good quaility and good fitting allen key to get it out if you damage it............. things will get much harder
olionel
My Bike: 98' ZXR400
Post by olionel »
would a hair dryer do as a hot air gun? :smt003
Thanks!
Oli
olionel wrote:would a hair dryer do as a hot air gun? :smt003
better than nothing
olionel
My Bike: 98' ZXR400
Post by olionel »
that bolt doesnt have to be tightened to a specific torque does it? as its not a missively moving part? I really need a manual I think.. :smt003
Thanks!
Oli
Every nut and bolt has a specfic toque setting.
If you over tighten any bolt it will be stretched and therefore weakened.
I found the front brake caliper bolts on my old CBR 600 had stretched by nearly 5mm they were supposed to be 45mm long but one of them was nearly 50mm It was a race bike and the caliper bolts were in and out all the time.
Anyway the gear pedal lever bolt on you ZXR has a torque setting of 25NM or in old fashioned money 18ftlb.
A drop of grease on the bit that the lever pivots on would be good as well and of course some thread lock on the threads
olionel
My Bike: 98' ZXR400
Post by olionel »
thanks very much. Do the 2 bolts that hold the assembly on to the chassis have any torque settings by the way? and what is it for the generator cover bolts? Thanks!
Thanks!
Oli
