Cylinder Problem
- Little Loris
- My Bike: 2008 Yamaha R6
Cylinder Problem
I fired up my track day bike today only to find it firing on 2 cylinders, which is odd as it was running fine a couple of weeks ago. Charged battery and changed 2 middle plugs for new ones (2 & 3) and it misfired into running 3 cylinders. Swapped plugs 3 & 4 and it ran on 2 cylinders again. Swapped them back and changed 1 & 2 only to find it running on 2 cylinders again.
Plugs don't seem damp or covered in oil and I've had a spark from all of them. Anyone know what the problem might be? Coils aren't damp either and all connected properly. It's running a total loss system if makes a difference to any problem solving! Please help!
- Little Loris
have you checked the earth straps are in good nick, what about the wiring to the coils?
Northern ANdy
- My Bike: Unique ZXR400
- Little Loris
Northern ANdy
make yourself a new HT lead up and swap them one by one checking for a GOOD bright spark.
ratbag56
- My Bike: zxr400 / 636
- Little Loris
Swapped the coils over after it failed to fire on 1 & 4 and it ran on all 4 cylinders
Great news but bloody confusing! Swapped them back to original position and fired again on all 4 with a pop from the exhaust every now and then. Very odd but guess it was a dodgy connection somewhere.
Funny thing is, the tacho had been wired up prior to start of all this and it wasn't working but when I switched the coils over it was going backwards?! After I swapped them back to normal it was working at all. What wires could be wrong?
ratbag56
- Little Loris
- Little Loris
Went on a track day to test the ZXR400. Got it firing on all 4 cylinders after the routine swap of the coils and HT leads. As soon as I pulled away and put it into 2nd and the revs picked up it went back onto 2 cylinders.
Pulled into the pits and it fired back into all 4
. Went back out again and back onto 2 cylinders. What the hell is going on?!
Is there any way of testing the coils or HT leads? How do I do it? Is something wrong with the CDi unit? Please help!!
if you hold it at a constant rev's (say 9,000) dos it go back to 2 then?
if it dosnt do the above you must have a lose conection what only happens as the vibrations pick up!
- Little Loris
