Stuck in gear!
pikemike
Stuck in gear!
Post by pikemike »
Hello, i just bought a 1990 ZXR400 H2 :smt003 . However its stuck in gear, the guy i bought it off said he noticed it was leaking oil and turned it off straight away and now its stuck in 2nd gear! Any idea on what the prob is, or how to fix it? :smt017 :smt017 :smt017
does the engine turn over? sounds like the selector forks may have worn away.
Northern ANdy
My Bike: Unique ZXR400
Post by Northern ANdy »
does the selector shaft move? or is that solid too
Andy
pikemike
Post by pikemike »
the bikes being deliverd next week i havent acctually seen it but as far as i know the engine does turn over, and the cluch goes in but everything else is locked at the foot.
Black Box
Post by Black Box »
Take the clutch out behind it there is a screw with a plate and a key hole that holds the selector fork in place. What happend to me is the bike was stuck in 5th gear... All you need to do is put the plate in possition again and tighten the bolt.. Use some locktite... :smt003
Life begins @ 14000 Rpm
pikemike
Post by pikemike »
i hope thats the fault, i bought a whole new set of gears just in case they have crunched up cause they were going cheap (38 quid deliverd off a write off ). but the easier fixed the better.
