Need new ignition
Fuuuuush
Need new ignition
My zxr's had its ignition messed up by someone tryin to steal it with a screw driver and i need to remove the ignition and steering lock to fit a new one....how do i go about this cause the two "bolts" i can see have just a "circle" allen key shape??
they are probably the original security bolts or someone has replaced them in the past with security bolts, they come with a hex head which snaps off at the right torque, you have to drill them out mate unfortunately, most people replace them with std cap head bolts.
