Bar Risers
lucietee
Bar Risers
Post by lucietee »
Hi All,
Just wondering if it is possible to get bar risers for the ZXR400?
I'm looking to buy a L9 model but would benefit from the bars being a little higher given my short stature and little arms!!
Does any one have any idea if it is possible to get hold of bar risers to fit the bike and if so where can i get them from?
Many thanks for your help
Lucie
you can get risers to fit sportsbikes but bear in mind you will almost certainly have to chop the top fairing to clear the bars.
you have several options, you can drill your existing yoke and fit std risers available everywhere, ebay, demon-tweeks, busters etc.
you can try and get a replacement yoke thats made for risers, or you can get some risers with clamps that fit on the forks.
Dylan
Post by Dylan »
It sounds like a lot of hassle. You might try loosening the handle bars and making sure they are as far back as they go, and then tighten them up again.
Might make 1 cm difference!
Dyl
deviant
Post by deviant »
i'd guess what lucie had in mind was probably raised clip ons rather than a one piece/clamped bar (as in the pictures in baz's post).
here's some for an sv650:
http://cgi.ebay.co.uk/SUZUKI-SV1000-SV6 ... dZViewItem
if you could find some to fit the zxr forks then it would be a pretty easy bolt on (although as said above, clearance to the fairing on full lock might be an issue).
SV ones obviously wont fit as they have RWU forks, but if you measured the ZXR fork tube diameter and then found what else has the same diameter then you would have a few more options.
steven2558
Post by steven2558 »
:smt006 bar risers??no no cant do that!!! :smt010
wot about a cushion on the seat to raise an hence give longer reach???LOL :smt017
never let your beloved slide across the tarmac on her own....keep hold of yer bike!!!!!!!
id say raise the rear and drop the forks down a bit
deviant wrote:i'd guess what lucie had in mind was probably raised clip ons rather than a one piece/clamped bar (as in the pictures in baz's post).
thats the ones i was looking for mate, well done on findin em! i knew you could get em somewhere.
deviant
Post by deviant »
sadly none that might fit a ZXR
wonderpupp
My Bike: ZX6R P7F
Post by wonderpupp »
Just do what my instructor told me, oh so many years ago...
PUSH YOUR BEAVER INTO THE TANK, GIRL.
he he. It works, you know.
Surely theres better things to push your beaver into than the petrol tank?
