Hi Guys,
At what point on teh temp gauge should the radiator fan kick in? Noit sure if mine is working properly.
Radiator fan
Jackson
to test if you'r fan is working remove the wires from the fan switch and join them together with a bit of wire or similar, keep your fingers out of the way too!! i've seen someone do this and lose the tops of their fingers.
- deviant
- My Bike: ZXR400 L3
agree, it's easy enough to check.
fan on mine comes on a little bit above half way but before the next mark (as far as I remember, it's been a while since it got that hot
