does cold weather affect motor
steven2558
Post by steven2558 »
:smt006
hi everyone
does anybody know if cold weather affects the little 400 motor
mine in summer was superb yet this winter spits and bogs @6000rpm just before all hell breaks loose!!!!
help or ideas would be much apprieciated??
by the way happy new year to all members! :smt003
hi steven welcome to the forum!
Sounds like a flat spot, but for it to suddenly appear is a bit odd :smt017
Have you changed anything like the exhaust recently, or added a new air filter?
steven2558
:smt006
hi thanks for reply!!
no not done much really apart from havent used it hardly since summer,
:smt017 oh just changed to a 14t sproc .... and a clean!!!
its also kept in a unheated garage ,can electrics condensate or somethin???
cheers :smt012
If its been sat for that long then its might be gummed up carbs. The fuel crystalises and turns into a goo and blocks things up a bit.
My advice would be to run some Redex through a few times as thats great stuff for cleaning up carbs as well as the rest of the engine. Give that a go :smt001
as robB says more than likely a fuel problem mate, could be worth dropping the float bowls off and cleaning them out.
steven2558
:smt006
thanks for your help ...think ill try the redex first ! as droppin the floats maybe a bit technical for me,im a builder and used to swingin sledges about!!!! :smt003
will let every body know the outcome..
if you see in wanted section carbs the redex didnt work and ive f**ked the carbs up trying to clean them(with a hammer ofcourse!!!!!!!!!!!!!!!!!! ha ha)
only jokin thanks for help...
als can a smaller fuel filter restrict the flow?? as the one on mine is alot bigger than a new one that ive bought??
cheers....
steven2558 wrote::smt006
what do you build? igloos?
steven2558
:smt003 :smt003 very good!! left myself wide open for that one didnt i !!!!
:smt019
steven2558
:smt006 hi
ran redex through today,after about 1/2 hour it seemed to make a massive differance(revving faster)
thanks for your help everybody!! :smt003
Glad to hear it mate, has that flat spot cleared?
Just run that through, and see how it is after you put in petrol without the redex.
steven2558
:smt006
yep flat spot seems to of cleared!!
revs better but noisier though the exhaust!!!
(or that could be me imagining things????)
thanks again......... :smt003
steven2558
:smt006
give it another run today after refuelling,and an airfilter,
its superurb now no problems(touch wood)
revs cleanly right through to redline with no hiccups!!!
cheers for your help everybody :smt041
