hi every1 after taking my zxr out for a blast (the first time in ages) i noticed that from tick over if i open the throttle too quickly the engine stutters asif it is flooding the tiny little bores. how can i avoid this? is it simple as carbs need balancing or wat? help much apreciated!
pete
throttle response
pete
only a ickle flatspot, probably needs a new airfilter and some carb cleaner blasted down the carbs, new plugs bobs your uncle.
- jake
