engine number location
grabejud
Post by grabejud »
it may sound stupid, but i was wondering where the engine number is located on a zx4RL7? i only found the chassis number...tnx
chassis number is on the headstock as you probably know and the engine number is on the right hand side above the clutch housing.
grabejud
Post by grabejud »
thanks alot mate..
mongo
Post by mongo »
masterofinsanity wrote:chassis number is on the headstock as you probably know and the engine number is on the right hand side above the clutch housing.
the engine number is there on most suzukis, however on the zxr the engine number is on the front of hte engine behind the exhaust downpipes, on a little shelf that sticks out towards the exhaust.
my memory must be failing drastically,, need more beer!!
grabejud
Post by grabejud »
thanks for the tip, havent got the time to check it though...
