Changing the oil / oil filter
flamy5
Post by flamy5 »
Can anyone give me a brief guide on how to change a zxr's oil and replace the oil filter?
Firstly I need to locate the drain plug and then to completley replace the oil filter, i'd appreciate any help with this or even a basic list of things I have to do and where to locate them.
:smt001
richard_ha
Post by richard_ha »
Oil drain plug is the lowest one on the engine I believe, I think its a 17mm bolt. Take off the RH fairing and drain the oil out from the plug then unscreen the oil filter (you can reach in between the engine and exhuast) screw in new oil filter, refit the drain plug (else you have a new slimey carpet that cost you about £20) then put new oil in. Very simple job. It's all in the manual.
greengoblin
My Bike: 96 ZX7R, 01 ZX6R
Post by greengoblin »
Couldn't have put it better myself ... :smt003
One thing though, who here replaces the sump washer when they replace the oil.
flamy5
Post by flamy5 »
Excellent, thanks for the help richard.
thats a job for this wkend i think :smt001
olionel
My Bike: 98' ZXR400
Post by olionel »
does the drain plug have a little washer/seal that needs replacing everytime? or doesnt it matter ?
Thanks!
Oli
you are recommended to change the sealing washer but as said above, who does it?
i did :smt010
olionel
My Bike: 98' ZXR400
Post by olionel »
well if you do is it a special thing, like a sump washer? Ive never seen it as Ive only had the bike for a month. Wont any washer with a bit of rubber do? Im guessing the part from the dealer will be about £4 or something... a gasket for the generator cover is £11+vat... grrr
Thanks!
Oli
olionel
My Bike: 98' ZXR400
Post by olionel »
ow 1 more thing? how tight does the filter need to be? (because they usually say a bit more than hand tight for cars...) is it same for the bike? or do I just screw it as far as it would go?
Thanks!
Oli
Northern ANdy
My Bike: Unique ZXR400
Post by Northern ANdy »
hand tight is fine, anything over is excessive. don't forget the smear of oil on the sealing lip, this still applies on bikes.
Andy
diesel
My Bike: Zx7r
Post by diesel »
i have mine to do. i have all i need. do u want a workshop section for it baz? i know for some of us its simple stuff but?????????
Quicker Than Yngwie
workshop section is for anything mate, gotta be better than the manual aint it??
if anyone needs washers let me know the size we have loads at work.
diesel
My Bike: Zx7r
Post by diesel »
canu do me one pls baz. i never changed mine :smt009
Quicker Than Yngwie
yeah if someone whips theirs off and lets me know the size i'll see what we've got.
diesel
My Bike: Zx7r
Post by diesel »
when i change mine ill let ya know
Quicker Than Yngwie
