Carb holder rubbers out of stock!
Posted: Wed Jun 21, 2023 1:35 pm
by Stuffie400
Good day all,
I think I have a bit of a problem here.. my Intake rubbers have started drawing air, I saw some are fairly cracked as well.
Now the problem is these intake rubbers (16065 1287) are out of stock everywhere and I cant find them 2nd hand either
Does anyone know if any intake rubbers from other bike models fit..? Or if I could fix them any other way... Thanks
Re: Carb holder rubbers out of stock!
Posted: Wed Aug 02, 2023 10:08 pm
by Poppa Wheelie
Have you tried Jauce.com
They bid on Japanese Yahoo auctions for you as your Proxy and handle the postage to UK
Posted: Fri Aug 04, 2023 8:24 am
by Miles
Is it leaking from the carb to the rubber, or the rubber to the engine?
There’s an o-ring under the inlet, if it’s leaking here you could fit new orings.
Posted: Mon Aug 07, 2023 9:07 pm
by Stuffie400
Poppa Wheelie wrote: Wed Aug 02, 2023 10:08 pm
I did search there, thanks for the tip tho.. but couldnt find anything on there unfortunately
Posted: Mon Aug 07, 2023 9:15 pm
by Stuffie400
Miles wrote: Fri Aug 04, 2023 8:24 am
Well the rubbers were cracking and brake cleaner test showed they were leaking through there.
The o rings were already fixed with extra sealant.
I tried to seal the cracks with glue as a temporary fix (worked pretty good actually) but there is still one spot that draws are, couldnt locate it exactly
The bike runs reasonably good through rev range tho.. Problems are: rough idle, tough cold start, no extra powerband at high rpm + doesnt go past 180kmh
Posted: Mon Aug 07, 2023 10:09 pm
by Miles
It’s not got the stock limiter does it?
What igniter does it have?
Posted: Wed Aug 09, 2023 4:03 pm
by Stuffie400
Miles wrote: Mon Aug 07, 2023 10:09 pm
It's got the blue "M" ignition box.. but as far as I know it should just do it's topspeed. After I rebuilt almost the complete bike it started and ran super well, wasn't even out of torque at 170kph.
But every ride after that things got rougher and now it's like I mentioned above
Maybe I'll try the 160651297 rubbers of a zrx400 but they probably won't fit
Posted: Wed Aug 09, 2023 6:49 pm
by banner001
The m cdi doesn't have a limiter, so if the bike is not going past 180kph or running rough the issue is not with the cdi.
Would need to check the usual things, carbs, fuel, coils, ht leads, compressions, plugs, timing, clearance etc.
Posted: Wed Aug 09, 2023 7:20 pm
by Stuffie400
banner001 wrote: Wed Aug 09, 2023 6:49 pm
Did a lot of maintenance (carbs cleaned, plugs, clearances, timing check), checked the intake rubbers for air leaks.. there were none.
Couple weeks later when it started running worse the intake rubbers did have air leaks
Anyway I think theres still some air leak now I cant find.. so im just trying to fix things one by one
Would it work if i strip the rubbers down to the metal flanges and use silicone hoses to clamp the carbs to the flanges/cylinderhead?
If all else fails I'll just throw a 600cc lump in
Posted: Mon Aug 28, 2023 7:11 pm
by Stuffie400
Little update:
I found 2nd hand inlet rubbers, found out they were in even worse condition (but the bike they came out off ran okay tho).. So that got me thinking
Put my old rubbers back on with a little sealant at the o ring.... No change at all, but also no air leaks to be found!
Now it seemed pretty clear its some ignition problem. Did some measuring, ignition/ pickup coils are within spec. But #2/3 coil got around 12V incoming current when cranking, #1/4 only got around 1.4V incoming current when cranking!
(the 2 red wires to coils are split from 1 of the red of the harnass(idk why))
So it seems its either a toad wiring harnass somehow or a defect ECU
Posted: Sat Sep 16, 2023 11:48 am
by Stuffie400
So I think I managed to make sort of a false diagnose.. not sure tho
Replaced all the electrics, wiring harnass, coils, ecu
and checked the carbs again (still clean), fuel tap
Nothing changed but spark seems good after all
Adjusted the pilot screws properly and balanced the carbs so idle is fairly good now.
But... I still miss loads of power in top rpm range. It just cant pull to the redline from 4th gear and higher.
It runs pretty smooth I think and it has the power surge at 6k rpm but then it just pulls at a continuous rate, no noticable increase in power in high revs..
Havent got a clue
Only thing I noticed when i tanked euro 100 petrol (red) is that the throttle shaft colours red
Posted: Sat Sep 16, 2023 3:36 pm
by Miles
What Fuel are you running ?
Posted: Sat Sep 16, 2023 11:11 pm
by Stuffie400
Miles wrote: Sat Sep 16, 2023 3:36 pm
Just premium petrol (Ron 98 e5 or Ron 100 e5)
Just cleaned the carb vacuum rubbers again, I'll check if that's done anything tomorrow
Posted: Sun Sep 17, 2023 2:20 pm
by Stuffie400
GOOD NEWS!! Pulled the carb rubber diaphragms out yesterday, carb cleaned the air jet in the rubber and carb passage to the air jet..
Put everything back together and went for a test ride today, ITS FIXED
, top range power band is back and pulls happily/strongly to redline in higher gears!
Now I totally get why its called a pocketrocket, what a small beast.
