Hi all
Just had my 400 fail Mot on the forks. Got them replaced OK but the rad needs replacing
Quick question.... do 1990 rads (which I think are curved not straight but stand to be corrected) fir the L models?
TIA
Replacement Radiator quick question
Dr Doalot
- My Bike: Ducati 996
watsonm359
- My Bike: ZXR400H2
Re: Replacement Radiator quick question
The only model to have a straight rad was the H1, after which all subsequent models had a curved rad. But, there is again a difference between the H2 and L rads which is the lugs for mounting. The H2 lugs are on the sides and the L’s are on top.
Hope that helps.
Hope that helps.
Good luck finding a rad for an L model... As rare as a rare thing gets
A recore will cost you £300 - 350 if that needs doing.
What's actually wrong with the rad?
Dr Doalot
Hi
Apparently it is leaking around the filler cap
You are right they are like hens teeth. H version more common for some reason.
I did find one from Romania inc fan. Cost €103 and as we are no longer in the EU delivery was €90 (instead of €10!)
Found it by searching on part no rather than description
