Which zxr 400 engine
Olivera35
- My Bike: tzxr 400
Hi new to this forum so apologies if this has been covered before or is in the wrong place I have a zxr400 engine that's been setting the shed for years I believe it's an l model but not sure what year or whether it is actually l model or not how can I tell thanks Adam
Re: Which zxr 400 engine
Which side of the bike does the coolant exit the bike towards?
If it points to the left (away from the clutch) then it's a H, if it points to the right then it's an L
Olivera35
- My Bike: tzxr 400
I will have a look. Thanks
Olivera35
- My Bike: tzxr 400
Hi just had a look. Do you mean where it comes out the barrels? If so it goes left into a rubber pipe then down a solid pipe into the water pump. Thanks
Hi there , you have the flow the wrong way.
Coolant goes from the pump (LHS) through that pipe into the barrels, it then exits the cylinder head from above the pipe you described above and either goes left (H model), or right (L model)
Olivera35
- My Bike: tzxr 400
Ah yes I see it's a L. Thanks for your help. One more question
will this L engine fit into a h frame?
Should do, I "think" all the mounting points are the same.
