Cam chain rattle?
Fredek5243
My Bike: ZXR400 L8
Cam chain rattle?
Post by Fredek5243 »
Hey guys,
I'm a new rider from Austria near Vienna, but since the german forum is kinda dead and doesn't accept new members, I decided to join here :)
But let's get to the issue at hand (which seems to be a common one I guess?)
When the engine is cold everything seems to run normal but after warming up, there is a rattling sound coming from the right side of the engine. It is usually not audible below 2k RPM or above ~4-5k RPM (but it might be the engine sound overpowering it), doesn't matter which gear, moving or not or clutch pulled /not, it is simply dependent on the RPM (also the pitch stays the same if that makes a difference). I uploaded a video to maybe clear things up a bit: https://youtu.be/ViAINe5L7sg (the recording is not perfect but it definitely doesn't sound normal).
I assumed that the chain might have gotten too loose but wouldn't the tensioner be extended fully in that case? I checked it (cold) and it was only about halfway:
Even after warming up, it was not fully extended(but more than when cold, because heat expansion I guess)
I bought the bike in mid-october 2019 and the previous owner told me about the rattle before the purchase but then said he fixed it (which it was for a short time). Stupid me shouldn't have bought it but after a test ride I just wanted to have it :smt119
Don't know if this is related, but he told me they replaced two rocker arms (can send pic, they were really worn out :o (this was not the fix, they did it a while before)
Anyway, I hope anyone can help out, should I just replace the chain, the tensioner, or both? Or is it something entirely else :smt017
schnecks
My Bike: zxr400
Re: Cam chain rattle?
Post by schnecks »
Servas!
The chain tensioner is probably the problem. You shouldn't be able to push the tensioner back in, as far as I know. Your chain kind of stays in place because of the spring inside of the tensioner but that's not enough to keep the chain under tension when the engine is running.
As far as YouTube diagnostic goes, I am pretty sure that's your problem.
Fredek5243
My Bike: ZXR400 L8
So the cam chain tensioner is definitely shot(only ones I found new are ~110€ which seems kinda expensive but I guess that is how it is now ) but the chain will also need replacing sooner or later(rather sooner as I plan on taking it to the track some day) Now I guess I should also be replacing the guides (parts 12053A-C) but the problem is I can't find A an B anywhere, they are just not available anymore. Should I just replace the one I can get or none(or do you maybe know some place I can get it)? A friend found a whole set but that comes from china and due to corona it probably won't be arriving here anytime soon.
Stuffie400
Post by Stuffie400 »
Hi @Fredek5243 Did you fix it in the end? You just replaced tensioner, guides and chain?
Stuffie400
Fredek5243 wrote: Thu Mar 12, 2020 9:14 am So the cam chain tensioner is definitely shot(only ones I found new are ~110€ which seems kinda expensive but I guess that is how it is now ) but the chain will also need replacing sooner or later(rather sooner as I plan on taking it to the track some day) Now I guess I should also be replacing the guides (parts 12053A-C) but the problem is I can't find A an B anywhere, they are just not available anymore. Should I just replace the one I can get or none(or do you maybe know some place I can get it)? A friend found a whole set but that comes from china and due to corona it probably won't be arriving here anytime soon.
Fredek5243
My Bike: ZXR400 L8
yes, I replaced the tensioner and the chain. I couldn't find the guides, and those weren't really a problem so I left them as they were. This fixed my issues, however it really needs a carburetor service which I can't be bothered to do, so the bike has been rotting away since then, so I can't really tell if the the problem has been permanently fixed.
They all rattle a little bit below 3k rpm...
