Right hand crankcase query.
Posted: Sun Dec 02, 2018 7:12 pm
by MRLZXR400
Hi,
On my L9, next to the oil pressure adapter plug on the right hand crank case is a 10mm hex bolt and nut.
On mine this nut and bolt looks fairly new and has a very slight oil weep.
I can't identify it in the manual and wondered what this bolt and nut does.
The bolt is in halfway with the nut locking it.
I'd like to remove it and fit a copper washer but I'm not sure if it's standard or what would happen if I remove it.
Any advice appreciated.
Re: Right hand crankcase query.
Posted: Sun Dec 02, 2018 11:12 pm
by banner001
got a picture?
Posted: Mon Dec 03, 2018 9:01 am
by MRLZXR400
Thanks Banner.
Posted: Mon Dec 03, 2018 2:41 pm
by banner001
Can you take another picture that puts it into a bit more context?
It looks like it's going to be the chain tensioner, though I'm not good with the L9, the part looks different to the earlier bikes, but looks in the right sort of place.
If it is you will need to fit it back correctly, i.e. not fully extended...check the manual or the guides on here
Posted: Mon Dec 03, 2018 5:50 pm
by MRLZXR400
It makes sense that it's the cam chain tensioner. When I bought the bike recently it had just had a new one fitted which fits with the bolt looking newish.
Here's a more general pic of its location.
Thanks again for the help.
Things like that can be difficult when you don't have another bike/bike owner to reference it against.
Posted: Mon Dec 03, 2018 11:28 pm
by banner001
I can't be 100% sure, but to me it looks like someone has replaced the automatic chain tensioner with a manual chain tensioner...a bad idea IMO...probably the reason for the oil leak as it will never seal properly.
I would get a NOS automatic chain tensioner and use that.
Posted: Tue Dec 04, 2018 5:32 pm
by MRLZXR400
Thanks Banner, I'll take your advice.
I searched lots of pix and spares websites and couldn't find anything that resembled it either.
I'm pretty sure I have the invoice for the work, I'll call them and see if they can recall what they did.
Posted: Mon Jan 07, 2019 5:51 pm
by MRLZXR400
Just so you know Banner I took your advice and replaced the manual cam chain tensioner that had been fitted with a genuine Kawasaki replacement.
What the garage (a supposed Kawasaki specialist) had done for the previous owner was to remove the spring loaded mechanism and then tapped the hole and fitted a bolt and lock-nut, it leaked oil and looked like a bit of a ropey job.
I followed the fitting instructions on here and it was pretty straightforward.
Thanks for your help on this.
Posted: Mon Jan 07, 2019 6:48 pm
by banner001
No worries, glad you are leak free
Posted: Tue Jan 08, 2019 10:00 am
by MRLZXR400
Thanks. It's also good to know my cam chain is no longer being tensioned by a 10p M10 galavanised nut and bolt from B&Q!
