Subsequently to a bad breaking with my 1994 zxr 400(my stock rear shock absorber nearly exploded after being seized during an hard track day), i've changed it for a more recent shock absorber from a later zxr400 (i think 2002?).
The shock mount and is visually similar (except for an external gas tank, wich mine did not had).
BUT
Once mounted, also if regulated to the end, the bike feel a little bit "seated" on the back, and i think is about 15-25mm lower.
Someone have any thoughts? In which way i could measure the real rear lowering? Have any datas about the rear seat height?
