L model carbs any different to h model
Zxr400paul
Post by Zxr400paul »
Hi all, was wondering if L model carbs are different to H model carbs and if they are how can you tell the difference, thanks Paul.
Miles
My Bike: ZXR 400 L3
Re: L model carbs any different to h model
Post by Miles »
If I remember the L carbs are 30 or 32mm bore.
I think the H is 28/30.
Whatever the bigger one is L
Ewetea
My Bike: ZXR400L5
Post by Ewetea »
The H had 98 main jets and N77C needles as standard, and the L had 95 main jets and N77S or N77R jets as standard. But both models had alternative main jets ranging from 92 to 102. Since the basic engine is the same for both models, it shouldn't matter which set of carbs are used because you will have to fine tune them for idle running and performance.
Zxr400paul
Thanks peoples!👍
