Juddery on full throttle
Locked
Aki
Post by Aki »
When accelerating hard my L1 gets very juddery from about 7000-10,000 rpm, Over about 10,000 revs its perfect and pulls hard. its completely de-restricted and has a K&N and sports can.
Anyone know why it would judder so bad?
It feels a bit like my old suzuki Rg 125 when the power valve was opening, went rather juddery.
Im a bit baffled!
Thanx, Guys+Gals!!
had it been dynojetted??
Xphyral
Post by Xphyral »
dunno what kind of juddery sensation you mean, but sounds like you got a flatspot from that race can. Re-jet and tune it out and things should be fine, if it is a flat spot it's not causing any harm other than probably a little annoying
Aki
Post by Aki »
it is very annoying and i've only been riding it today!!!! lol!
I dunno if its been dynojetted to be honest, the previous owner was a bit unsure of whats been done to it.
the_avenging_bucket
Post by the_avenging_bucket »
i get exactly those symptoms when i forget to replace the 2 blank-off plugs in the top of my airbox, or if i remove the little snorkel/ pipe thingy in the front of the airbox (removed it coz i thought bike would breath better, got nice torque low down but ran crap above 6000 7000 so put it back immediately)
basically the whole induction, exhaust system is very sensitive to changes.
'the people who are crazy enough to think
they can change the world, are the ones who do'
the_avenging_bucket
also check that you have a proper gasket/ seal between carbs and airbox.
don't jet the bike before you make sure the airbox is properly sealed.
the_avenging_bucket
read somewhere that the snorkel thingy doesna fit if u have the k&n filter, if that is the case, see if u can borrow a standard filter plus the snorkel thingy, testride with that to identify prob.
Aki
Post by Aki »
Thanx a lot for your help, I've got someone to have a quick look at air box and there apears to be a little gap where it joins too carbs so could be that?
I'll keep my eye on ebay for a new air filter box
the_avenging_bucket
yes.
makes a big difference. when i got my bike had same symptoms as yours, cause 1 of the blankoffs were missing as well as was sucking air between carbs and airbox...
i made a gasket out of 5mm foam camping matress material (tested it was fuelproof by leaving in fuel for a few days). i needed to use thick material cause my airbox is slightly warped where it joins the carbs.
after sealing box revved sweetly all the way through... but like i said make sure u have the pipe in the front of the airbox as well, removing that causes same symptoms...
good luck.
Locked
