e advice on this little problem!Starter motor is fine and turning over nicely, got a spark from every plug, only thing being is that i'm not sure if the fuel pump is running. If I connect the pump straight to a 12v then it spins for about a second and then stops, although I assume it will only pump up to a certain pressure when the float chambers are full and then cut off? Not sure if the relay has gone and I don't think I can test it, but even when the float chambers are full the bike may just
Any Suggestions??
