Carb adjusterizing
the_avenging_bucket
Carb adjusterizing
Post by the_avenging_bucket »
my ZXR rebuild is now almost complete, after riding the bike am a bit disappointed though :smt009
two factors:
1) live in pretoria, south africa, so pretty high altitude.
2) seal/gasket between carbs and airbox was non-existent, blankoff holes in airbox were gone.
i made a gasket and plugs to seal airbox properly, float bowl fuel level has been set and carbs have been synchronised with vacuum gauges. pilot screws adjusted for best idling. after these changes engine runs smooooth and climbs thru the rev range without a glitch all the way to redline :smt004
prob is, not enough power (also slow throttle response in nuetral) :smt019
floods very easily, soot deposit in can exit, and engine dies if you touch choke while idling(warmed up). this leads me to believe that the bike is running too rich... :smt017
how do i go about re-jetting the bike? (i want to DIY the job)
if i want to simply buy a few jets in different sizes (4 of each), what do i ask for? do all jets fit all carbs or do i need Keihin cvk-d32 jets?
Last edited by the_avenging_bucket on Tue Apr 25, 2006 3:22 pm, edited 1 time in total.
'the people who are crazy enough to think
they can change the world, are the ones who do'
sloweracing
Post by sloweracing »
Yes you will need Keihin jets are far as i know do a google search for the jets
And jetting is very simple at the bottom of the float bowl take out the 4 jets see what size they are then start down jetting but i would go down 3 sizes at a time but you should really Dyno the bike and then they should tell you what size is right for the job
Dont buy Kawasaki jets it will cost you the earth i use Bartons they good
http://www.bartonmotors.co.uk
Good luck mate
the_avenging_bucket
thanks a bunch! (love usefull info)
will get round to it in about two weeks time... will post the results :smt001
the_avenging_bucket
:smt017
mmmmmm hokay...
from zxrworld's partslist the mainjet is partno 92063...
from two other websites partno for cvk series mainjets is 99101-393.
is the former kawasaki and the latter keihin?
el confusedo grande!
guess i'll have to go shopping with a sample :smt012
damn life is hard :smt073
the_avenging_bucket wrote::smt017
mmmmmm hokay...
is the 99101-393 for later models than L3?
i have a set of microfiches for L4,L4A & L5 i will look at them tonight and let you know tommorrow.
the_avenging_bucket
i don't kno if 99101-393 is for teh cvk-d32... they only say for cvk range...
if l1 to l9 used cvk-d32 then they *should* use same jets though...
i'll just find someone in pretoria or jo'burg who sells jets, and take one of mine with...
dang south africa can be useless sometimes...
:smt117
CATCH TEH FRIKKEN CHICKEN JIMMY!!!
