German Zxr 400 L3 - Lightweight & Road Legal
Dominik
My Bike: Zxr 400 L3
Post by Dominik »
Hey ho guys,
time has come to show you some pictures and information of my 400. It´s an L3 with around 50.000 km now.
I rebuilt it to make it better and lighter but it needs to pass the german TÜV so I had to follow some rules...
However, take yourself a look:
It´s not finished at all and will get a new design in silver/ black/ white with brushed alloy accents.
Right now it weighs around 150kg without fuel.
Mods:
-Kawasaki ER6/ Verys 650 rims, lighter Z750 sprocket carrier and damper
-Lighter Front (300mm) and Rear (220mm) Discs
-Brembo rear brake caliper (one piston only)
-Oil cooler removed, fitted an alloy connection with included temperature "feeler"
-Engine work, lighter Flywheel, modded oem Airbox and Carbs
-Zx6r Rear Shock
-Dellorto Vacuum Fuel Pump
-Single Seat unit with PC40 Rear light fitted (integrated indicators), Rear frame modded and lightened
-Brembo Braking-Pump front and rear (with integrated reservoir)
-Braided Hoses front and rear
-Koso Rx2 Tachometer
-Jollymoto Carbon Endcan
-Modded Oem Rear Sets
-Alloy Sidestand
-Hollow Handlebar and swingarm axle (thanks for translating banner!)
-Alloy Bolts here and there
-Lightech Carbon mirrors
-Afam 3D lightweight racing chain, modded front sprocket, alloy rear sprocket
-smaller coolant reservoir
Still to come:
-electrical wate pump with silicon hoses and alloy tubes
-Higher Racing windshield
-Lightweight polyester fairing
-Zx6r Front forks with monoblocks and 280mm discs
-Uk Headlights
-Good Downpipes
-some more enginge work till around 70 rwhp
Zxr 400 SL - 130kg
Re: German Zxr 400 L3 - Lightweight & Road Legal
Hollow handlebars and swingarm is what you wrote.
CaNsA
My Bike: ZX6R F1
Post by CaNsA »
How much of that bike German?
:smt005
Dominik
My Bike: Zxr 400 L3
Post by Dominik »
Huh? And i thought no one would realise that...
Well license plate is and maybe some selfmade parts if you want
Zxr 400 SL - 130kg
Dominik
My Bike: Zxr 400 L3
Post by Dominik »
Some news, it´s slowly getting finished :)
Mra Racing windshield
Gearing Linkage removed, more direct (inverse) shifting
Rear Brake, master cylinder and caliper finished. I also made a lighter and adjustable bar.
some selfmade nuts, saving alsmost 100g (rearwheel, swingarm axle and top yoke nuts)
New fairing. Tank is getting brushed today :) Fender will be carbon with the zx6r fork lying around here
Zxr 400 SL - 130kg
richyrd5
My Bike: 400h
Post by richyrd5 »
:smt023 .some nice mods done there chap..looking good....some good ideas as well winks
Dominik
My Bike: Zxr 400 L3
Post by Dominik »
Couldn´t do the fuel tank as far as I wanted... Surface is prepared for finish only. Hope I´m getting finished tomorrow :smt015
If you ever wondered how the tank might look without... well without anything: now you know ;)
Zxr 400 SL - 130kg
Dominik
My Bike: Zxr 400 L3
Post by Dominik »
Green is getting rarer...
Alternative headlight mounting as there was none in this nose cone. You can uninstall the front mask pretty fast now^^ The mirrors will be mounted on the handle bars soon
Zxr 400 SL - 130kg
Dominik
My Bike: Zxr 400 L3
Post by Dominik »
I started installing the Zx6r Front fork today. Pretty good, all measurements are done and distances will be made this weekend. The Uk-Front light came today and was installed (half) today either. Thank you banner for shipping and help!
Tankcover went carbon/white from green/white
First hang in with 280mm front discs
Special made part for Koso RX2 speedometer, fits zx6r fork as much as the zxr 400 one
Tadaa, half installed UK-headlights. Almost a pound lighter and looks much better! Only need another cable as our loom has only one...
Zxr 400 SL - 130kg
no worries bud, build is looking good!
Dominik
My Bike: Zxr 400 L3
Post by Dominik »
Finished! :excited
Weight: 144kg / 317lbs with everything but fuel
Power: ~65rwhp
I´ll gather some experience with the new suspension and tell you how it works after some rides ;)
Zxr 400 SL - 130kg
richyrd5
My Bike: 400h
Post by richyrd5 »
smiler sweet;!
nice!! where did you get the carbon tank cover from?
Dominik
My Bike: Zxr 400 L3
Post by Dominik »
this isn´t a real carbon cover. It´s the standard one covered with a 3D-foil with elevated carbon pattern. Did this myself and worked quite ok but not overall. That´s the reason why the area where the tubes go in are still white.
Zxr 400 SL - 130kg
Flatcap
My Bike: ZXR 400 L4
Post by Flatcap »
Good work! With all the weight saving, make sure you don't put any weight on otherwise you wasted a lot of time and money :smt003
