Do I need a base gasket??
- My Bike: zxr400......suprisingly
Can I ditch the base gasket and simply use 3 bond instead?
- My Bike: 400h
Re: Do I need a base gasket??
Yes you could...but wouldn't recommend it as the gasket will affect squish/compression so would be best to use the gasket if you can...why do you want to use just sealer??
