1999 L9 loom
tink
- My Bike: ZXR400 L2
1999 L9 loom
Is there a difference between the 1999 L9 main loom and a 1991 L1 jap import
Re: 1999 L9 loom
yes...the one on ebay, there is a difference, but if you can source the L9 junction box (the L5 loom onwards is different to L1-4) then you should be fine...if you check the manual the L1-4 and L5+ wiring diagrams are fairly clear, check the differences between the two and see if you can make it fit...i would help you more, but i have an epic journey starting in 9 hours and i need some sleep
tink, did you ever buy a new reg/rec...its likely that that is your most likely culprit and why your wiring keeps frying itself.
tink
Re: 1999 L9 loom
Sorted a new loom now and gonna buy a new regulator before fitting it
