throttle cable
				alanh496
 - My Bike: zxr 400
throttle cable
Hi, I'm looking to make up a longer throttle opening cable to allow me to change the position of the clip-ons, and I need the plastic  adjuster  that  takes the cable  round  an  angle inside the twistgrip -  would anyone have a knackered cable  that I could take one  from ?
						- R P Corse
 - CBT slow
 - My Bike: ZXR400 H1
Re: throttle cable
speak to venhill about cables mate, they can make one up for you at whatever length you want/need
Re: throttle cable
GPz900R will fit but think a few other models also use same set-up too. With the GPz cables you will get screw n locknut fitting at the carb end, np to use on CVKs but excellent for FCRs
BTW, GPz are longer
GPz \ GPx 600R should be another option but slightly shorter than the 900s and have the normal end fitting to the CVKs on them.
									BTW, GPz are longer
