L model cylinder head on H
- R P Corse
 - CBT slow
 - My Bike: ZXR400 H1
Re: L model cylinder head on H
Need to be quite rough with new down pipes as they are stiff and have not been moved/fitted before
mine were ok in cylinders 1 and 4, but i had to open them out a bit to fit numbers 2 and 3.
				bendog66
I've got an H engine in my L4 and everything including the downpipes are from the L
						- R P Corse
 - CBT slow
Did you put copper washers/spacers on the cylinder manifolds?
						- R P Corse
 - CBT slow
im pretty sure the cylinder heads are the same throughout all models .... the engine had been unchanged apart from gearbox and clutch ... the L9 had "better" internals to give more power increase - someone correct me if i am wrong on that! but im pretty adament its a straight fit.
microfiches show them as being identical...heads, rocker covers...StuntRider wrote:Ok so I have found out the bottom of the heads are different as in there are more holes on the underneath of the l, landmark bikes sold me the head telling me there the same head and some part number WRONG, if any one has a good cylinder head let me know thanks
- R P Corse
 - CBT slow
im looking at the microfiche now, its the same part numbers.... would highly doubt kawasaki microfiche would be incorrect!
ah, unless the microfiche doesnt include the L9...it does have a few engine mods from the other L-models...?
again, still good to know that the microfiche here might not be the one for the L9?
- R P Corse
 - CBT slow
lists the L9 model, had to double check
						- Tirpitz
 - My Bike: Kawasaki ZXR400L4
You reckon? So have a look at the rear suspension linkages for the L here http://www.zxrworld.co.uk/images/Lseries/lrearshck.gif Notice the grease nipples for lubing the bearings part no. 49001-1051. Now tell me if you've seen an L with grease nipples.BigB wrote:would highly doubt kawasaki microfiche would be incorrect!
There are several items on the L fiches which don't apply to all (any?) models, so if this head issue is another one it wouldn't surprise me.
Hel braided hoses
Pirelli Diablos
Ohlins steering damper
A16 carbon fibre exhaust can
Nitron Sport shock
						Hel braided hoses
Pirelli Diablos
Nitron Sport shock
