flames out of exhaust ports since rebuild
- Restricted
- My Bike: zxr 400 l6
hi all, ive recently done a rebuild on my l6. realised the head gasket had gone so decided what the hell im going to do it myself. save myself money and learn
i put it back together and the only problem i had was with the timing. i put some petrol in and tried to start it using easy start. i haven't put the exhaust on as im waiting for the gaskets. when i started it it reved like crazy and when i looked down their was flames shooting out of the exhaust ports. im just wondering if this is something to worry about? i have a small feeling that the timing may not be 100% spot on but i want to find out if it is neccesary for me to take the engine apart again. thanks
- My Bike: Kawasaki ZXR400H2
Re: flames out of exhaust ports since rebuild
Not sure its a massive thing to worry about - as far as I know its fairly normal to get spurts of flame from the exhaust ports. You are after all releasing the products of a controlled explosion! As long as the timing isn't affecting the valves you shoild be reasonably safe. Before fully rebuilding just recheck the valve and ignition timing, you may need a strobe gun for this.
Its normal to get flames out especially if u haven't got the headers on. Long as the timing is done as per the manual it should be fine.
thats Easy start for you lol bloody good stuff!
