Low compresion rate
Posted: Wed May 16, 2012 8:24 am
hello,
I have a question regarding the compresion ratio of my zxr 400 L6 from 1996
Due to my idle problems (viewtopic.php?f=166&t=13657) i took the bike to a mechanic. There i don't know the reason (could be lack of interest for my bike or lazyness) the mecanic
said that i have a low compresion rate in my cylinders and said he will check it.
Yesterday he called me and said that my compresion rate is 2 bar (around 29 psi....1bar=14.5 psi) . i didn't understand if it was in total - 0.5 per cylinder or per one cylinder.
Anyway i read the manual and there it specifyes that the comp rate per cylinder is from 99 to 156 psi ( 6-10 bar) which had me puzzeled.
Can a motor run and behave nice whith such low comp rate? ( 3 to 5 times lower than normal)
There are no signs of low comp rate - plenty of power from 3000 rpm all way to 10.000
Easy start - hot and cold
The only problem is with idle rpm @ 1.5 k (above 2.2 k idles without a problem)
Could the mecanic be wrong? And just said that cause he is not in mood to fix my bike? (and ofcourse to make easy money)
Worst case scenario - if indeed the mecanic is right and the comp rate is 2 bar (29 psi) what are the steps to solve my problem?
thanks!
thanks!
