2nd gear crunching...
pulling out from work today (hard-ish on the gas) i shift from 1st to 2nd, the gear missed, made a crunching sound and now i have this horrible crunching sound and vibration through the gear lever when in 2nd gear. does not happen in any other gear and seems worse in decelaration rather than acceleration.
i am wondering whether i have fecked up the 2nd gear cog, like snapped a tooth off?? also as there is no apparant problem in any other gear is the bike still "usable", or is this problem likely to spill over and cause problems for some other component.
my major worry is that something has snapped off and will lodge somewhere it shouldnt...fucking hell!!! :smt013
also, whats a likely cost to have this fixed at a garage? i will ring up my usual place on monday.
Re: 2nd gear crunching...
You could check the oil for signs of parts but other than getting it apart id wait n talk to your usual place.
drained the oil, no sign of anything, doesnt look any different from how i would have imagined it.
dropping the engine tonight/tomorrow, garage has quoted me ~£200 in labour plus parts...hmmm wondering if i can do it myself now...i was wondering, do i need to dismantle and remove the clutch in order to get to the transmission, its a bit hard to see from the manual.
btw if anyone wants to drop down to cov to assist us feel free...i will pay you something for your troubles...
ok there is a DIY garage here in cov, gonna do the work there, plus i kinda know the owner so that should be ok.
if someone can do a quick checklist for me to do to get at the gearchain that would be excellent
before i start, do i need to remove the cylinder head at all?
also, is it possible to turn the engine "upside down" when splitting the crankcase in order to leave the pistons in the bores - i have heard that they are a pain to get back in?
and lastly, what happens to the cam chain when i remove everything, i assume that it remains attached to the crankshaft assembly...but i would have thought that that would come apart when i split the cases? or does that remain in the upper half of the crankcase, whilst the transmission is held in place in the lower crankcase?
cheers
cheers
- Tirpitz
- My Bike: Kawasaki ZXR400L4
£200 in labour plus parts is an absolute bargain but I'd want that in writing. There is a LOT of work here and working on a gearbox and splitting the crankcases is just about the most complicated job you can do on a bike, it is not the work for a novice. I really don't recommend you try this yourself as you don't sound to me as though you have anywhere near like the mechanical skills to pull it off ('getting at the gearchain' etc shows you don't have a clue - I'm not trying to be rude, just honest to save you a lot of pain). Yes, you do need to take the cylinder head off! You need to take the engine completely to bits more or less, this is a major job.
If you've buggered the gearbox then economically you may well be better off buying a new engine unless you are a skilled mechanic. Yes, it is that serious I'm afraid
Hel braided hoses
Pirelli Diablos
Ohlins steering damper
A16 carbon fibre exhaust can
Nitron Sport shock
Hel braided hoses
Pirelli Diablos
Nitron Sport shock
rmkd177
Sorry to contradict you 'Tirpitz' but you dont need to take the head off to do the gearbox....no need to touch the top end....head...pistons...cams ect all stay in place....its a fairly simple job and i would do it for £100 plus parts and i will definitly have everything in stock. Pity you live so far away 'banner001'
R.Middleton
- CaNsA
- My Bike: ZX6R F1
Mr. Middleton.... Where do you reside squire?
- Tirpitz
Sorry Roger well corrected, you're right to contradict my talking rubbishrmkd177 wrote:Sorry to contradict you 'Tirpitz' but you dont need to take the head off to do the gearbox....no need to touch the top end....head...pistons...cams ect all stay in place....its a fairly simple job and i would do it for £100 plus parts and i will definitly have everything in stock. Pity you live so far away 'banner001'
Banner - there's no way you want to be buggering about with this job as a novice when Roger will do it for that price. I couldn't even begin to be arsed for that money. Even from Coventry I'd be looking to get it in a car and deliver it to him - even with the petrol it's a no-brainer.
Hel braided hoses
Pirelli Diablos
Nitron Sport shock
Hel braided hoses
Pirelli Diablos
Nitron Sport shock
im originally from huddersfield, my dads a joiner so he's up and down the M1 all the time going back to huddersfield, he might be able to pick it up and drop it off...i have a funny feeling that roger is in york, so not far from huddersfield, might even be able to get it posted from there to his.
and yeah for £100 i cant go wrong.
- Tirpitz
........ is the right answerbanner001 wrote:i have a funny feeling that roger is in york
Hel braided hoses
Pirelli Diablos
Nitron Sport shock
Hel braided hoses
Pirelli Diablos
Nitron Sport shock
gonna see about getting the valve clearances sorted, and get the cam chain looked at/adjusted at the same time.
Thankyou, thankyou, thankyou to Roger for the engine help!
Cannot thank him enough for all his help, it was the second gear, i had snapped a tooth of the 19T sprocket, ill put up a pic later on. Gonna get the radiator and oil cooler back on, stick in some oil and coolant, feed it some fuel, get the carbs synched and see how everything sounds!
gonna take the forks apart and get back on the road within the week hopefully
pleased to hear you got it sorted. Think thats got to be the first time ive heard of a tooth going astray.
Pick of the fubar gear and loose tooth.
