One hour yesterday in our local DVLA and it's MOTd , Taxed , insured & new reg' plate
Well not exactly, I bought a frame that was still registered so the seller sent me the paperwork and licence plate to get transfered then the frame arrives tomorrow.
Pretty sure I have everything to build it from the ground up hence the title of this thread , there's going to be a heap of boxes being opened and raided.
Seeing as it has already got it's legals I am giving myself a month to get this one up and running - it's going to be for sale so wont be getting the trick stuff on it.
Standard carbs with airbox , RPM 4-2-1 system , an H1 swingarm as have oodles of those , H2 forks , Green/White n Blue two seater bodywork & OEM rearsets.
Engine is a tricky one though - I think I have a standard H or L on veranda that needs worked on. From memory the output shaft isn't engaging so might have a dodgy gearbox in it. Got no room to be stripping an engine down to it's essentials so I really just want a top end overhaul candidate. The J1 & J2 motors seem to have no prob's with them so with their age and sitting so long will do a head gasket change with valve stem seals - got the kits in the cupboard but I don't want to sell the SP motors
Alternative is to shove the SP motor in my current bike and then use the H2 engine in this one but that motor is rock solid so again a bit hesitant to sell it on too
So this weekend I will make a start as the motor is going to be needed pronto , forks are also needing new seals into them but want to swap the springs with the ones in my other J2 set
It will have a J2 SP rear shock though as I have no alternatives unless I snatch a bargain soonish
So , although 1 month sounds plenty it's only 8 days of weekends and what I can squeeze in through the week.
Should be good
