Hi all, I am doing a wheel swap on an old Kawasaki Turbo, I have bought some ZXR400 wheels which I believe are L wheels, but I am now told I need H wheels! So my question to you guys is, what is the difference between H and L wheels other than the larger rear wheel spindle on the L wheels??? Also if the are the same what is the chance of finding the spacer that goes into the sprocket side bearing for an H (17mm spindle) as I would assume I can just swap bearings and use the later wheels.
Thanks for your help on the first of many questions
Phil
