H model Solenoid on an L model loom
Posted: Fri Jun 24, 2011 10:47 pm
by stevezx7r
Hi, does the H model starter solenoid work on an L model loom?
Thanks.
Re: H model Solenoid on an L model loom
Posted: Sat Jun 25, 2011 1:29 pm
by Tirpitz
If you look at the part number fiches on here and the aprt numbers are the same then the answer is 'yes', if they are different tnen 'no. Probably 'yes', but an easy check for you to do.
