sp wiring loom
mitchpaul
My Bike: zxr400l 1993
sp wiring loom
Post by mitchpaul »
Trying to make up a 1996 race wiring loom for a 1996 400sp i followed one i down loaded but no spark does any one have good diagram of wires going into the mitzy cdi plugs any advise would be great i do have the resistor on the grey wire
mick41zxr
My Bike: ZXR400sp
Re: sp wiring loom
Post by mick41zxr »
What CDI are you using, the kit looms used a kit CDI, I could never get the std SP CDI's to run properly. Also remember the SP used a different tone/timing wheel.
mitchpaul
Re: sp wiring loom
Post by mitchpaul »
i am using std sp mitsubishi cdi, it was running fine until i made up the 1991 sp loom (i found on this site),the bike is a 1996 i need to no the numbering system on plugs to check my colours,also i have not put in the throttle sensor part of loom in , but i shoud get spark ok
stevi5
My Bike: many
Re: sp wiring loom
Post by stevi5 »
Should work with any cdi unit as long as your wiring is correct and you have the 100 ohm resister in the right place.
