calliper seals
ayjay
- My Bike: Fazer 1000
calliper seals
Hi where do you guys get your front calliper seals from for the zxr 400 l twin pots?
thanks
- Tirpitz
- My Bike: Kawasaki ZXR400L4
Re: calliper seals
Wemoto do pattern seals http://www.wemoto.com/bikes/Kawasaki/ZX ... ont_Brake/ . I rebuilt my front calipers with these and have had no problems with them. You can get OEM from Cradley Kawasaki (see top of page banner ads) but I see no reason to use them. The front seals are the same throughout the L range but beware that the rear caliper changed from L3 - L4 model and onwards, so if you do the rear make sure you get the correct ones, they do not interchange.
If you split the calipers for any reason you will need to go OEM for the little rubber gaskets which fit between, no-one does pattern and reusing the old ones is not recommended.
Hel braided hoses
Pirelli Diablos
Ohlins steering damper
A16 carbon fibre exhaust can
Nitron Sport shock
Hel braided hoses
Pirelli Diablos
Nitron Sport shock
