A big hello and my ZXR 250
Richard2703
My Bike: ZXR 250
Post by Richard2703 »
Hey guys,
My name is Richard, i'm 23 and I live in London. Recently bought a ZXR 250. I know this is a 400 forum but hopefully there are some similarities and I can get a few tips.
Anyone own or owned a 250 here?
Re: A big hello and my ZXR 250
wlcum
And no I've not come across one of them !
Do tell us all about it. Is it a four cylinder ?
Richard2703
My Bike: ZXR 250
It is indeed. This is the 'Real' Ninja 250, not a parallel twin commuter with fancy bodywork :tease
Red line starting at 19,000 RPM, by the way. I still haven't ridden it, only had it started for a few seconds. It's currently in my sitting room downstairs lol. Will need a few things done, like fork seals (I was hoping for a bit of advice on that), indicator relay and lights. Apart from that, she looks good.
The forks look quite similiar to 400 ones..............lots topics on forks if you use the search box top right of the page you find them
I assume it's a Japanese market bike and grey imported ?
Mori Man will I'm sure be aware of it
Richard2703
My Bike: ZXR 250
Yes, it is - it was meant only for the Japanesse market. I couldn't even guess how many there are in the UK (not many)
Always wanted a 250 inline 4 - love the sound really
bendog66
Post by bendog66 »
anybody else looking at the rear caliper and wondering whether it would fit on a 400 or is that just me?
bendog66 wrote:anybody else looking at the rear caliper and wondering whether it would fit on a 400 or is that just me?
Only if that bracket fits id have thought.
Welcome to the forum, didnt realise there was a 2 and 4 cylinder ZXR250, i knew of the 2cylinder. Be nice to hear that run.
bendog66
Post by bendog66 »
the bracket goes through the spindle, although you would need to mod the swing arm for the slidey bit (technical term). Just a thought
welcome to zxrworld and you are very welcome, always wanted a zxr250 but as you say there aint many around.keep us updated with it.
Richard2703
My Bike: ZXR 250
Yup, will definately keep you boys updated - need to do a lot to ger her 'right'. Few electrical issues, fork seals, throttle sticking, need mud/chain guard and also want an exhaust. Hopefully will post a vid once I take her out but that won't be for a few months yet.
Mori Man
Blingmeister
Blingmeister
My Bike: ZXR400J2
Post by Mori Man »
Hi Rich,
Unfortunately the bike shares the same name and look as the 400 but that's about it , headlights and taillights are the same though. Clocks and forks look the same but do differ.
The ZXR400 has a road brother called the Xanthius , the 250's is the Balius - they share the same engine, being naked the casings are different looking but internals are the same. The original A is the one to have with the high reving motor, later models started to be restricted with a lesser red line.
ZXR250 Engine:
Balius Engine:
I think ZXR400H forks with tripples drop in with out much fuss , the 250 forks are used as a USD conversion on the ZRX400 , less common is using the 400 H forks but I done that on my bike no problems so they should share same bearings.
I've actually got a BEET Aero shark fin front fender here (Uber rare) for the 250 , about to send it back as it was sold to me as one for the 400. Uprating the front end to a 400 will give you a 120 profile tyre.
You might be able to fit a H swinger as well ( axle should be correct) but you would want the complete back end and get a 160 profile tyre on the back :smt003
Balius zorsts should swap over like the xanthius does for the 400 but there may be fouling problems with the cowl(s) - RPM still make new systems for the 250 but there are plenty makers for the Balius , Nojima make a nice Ti/carbon system that sounds pretty darn good :smt004
RPM Webby: http://rpm421.com/seihin-joho-muffler-s ... xr250.html
ZXR250 Zorsts: http://auctions.search.yahoo.co.jp/sear ... rce&mode=1
Balius Zorsts: http://auctions.search.yahoo.co.jp/sear ... e&slider=0
If you have problems sourcing parts just give me a shout plenty used stuff about and some new parts still available too.
ATB,
MM! :smt001
Richard2703
My Bike: ZXR 250
Hey guys,
Sorry for the late reply and thanks for the links Mori Man!
A bit of an update on the ZXR 250:
Throttle sorted, indicators didn't work because the battery was low so now work fine, brake switch was mashed so replaced that with a standard Kawasaki one (they seem all the same). Bike didn't start to begin with and turned out the air filter was filthy. So I washed it and cleaned it out but it deteriorated a little. Took it out after that and came back with a big grin - what a sound! I think it's a little too loud because of the filter.
Bike is now getting seals done. However, still a few probs:
Firstly, the revs don't want to drop below 4,000. Apart from that it's revs fine. (Bit dangerous)
Secondly, when I was taking it to the garage, it suddenly lost all power - there was no response from the throttle in all gears, was doing about 50-55.
Could this be all down to the air filter?
extonyg
My Bike: zxr 400 L1 uk
Post by extonyg »
i wouldnt ride around too long without an air filter as you dont want the carbs to suck crap from the road in, and yes you will get alot of induction noise from no airfilter and this could also cause the revs to hang
Richard2703
My Bike: ZXR 250
The filter is still there - I wouldn't think of riding it without one. It's just that it deteriorated a little. The filter basically looks like a hat and the ends have come off. I'm actually going to order one right now - was just hoping that that's the only problem
extonyg
Post by extonyg »
make sure the airbox is secure as this can cause and air leak causing the revs to hang
