Hey finally took the new engine out for a ride the other day and from what it sounds like it is running very nicely even better then my other two lol.
However halfway through the ride the bike began to sound slightly boggy. So I had a look at some of the threads and I kinda had the same problem as Cameron 'Running Lumpy as hell'.
When I cam to check over the bike I managed to forget to tighten the screws where the inlets rubbers are will this have cause the boggy effect???
Also #1 carb had a bit of condensation and the float is slightly sticky what kind of running problems would happen with the bike what should I notice?
Ciaran
Would would the symptoms be?????
- U_h0rnet5
- My Bike: ZXR400
- U_h0rnet5
- My Bike: ZXR400
Re: Would would the symptoms be?????
Its alright looks like it was that I left the inlet rubbers loose and I took the diaphragm/float out of the carb and cleaned it up so it move smoothly in the carb. Going to take it out for a spin tomorrow to see how see goes, hopefully well but not promising lol
