Carb heater removal
motoxxx
My Bike: ZXR400 H1 Race bike
Carb heater removal
Post by motoxxx »
Hi all
Ive got a second hand motor that came with carbs. i've blocked the hole on the engine where the outlet is.
I want to remove the carb heater stuff from the carbs. do i just block the tubes or is there another way to do it?
Re: Carb heater removal
I think you can just pull out the tubes from the carbs, else you could just disconnect the main tubes and leave the smaller ones attached.
