No. 4 carb issue
Posted: Wed Jul 28, 2010 3:58 pm
Hi, having a little trouble with one of my zxr carbs.
The No.4 carb seems to be running rich by a quick look at the plugs.
Started it without the airbox and balanced them, on the same carb, the slide moves before all the others and bounces up and down on idle when the others are dead still.
Told it could be an O ring gone somewhere, balancing them doesn't seem to have any effect so I'm guessing it's an issue with the carb itself.
It runs pretty badly at low rpm and runs a bit boggy until around 4k when it's pretty un-noticable.
Any help is much appreciated.
