However, when it's idling after a few seconds or so it will go all 'lumpy' and uneven and then stop
Anything above idle it's much better, noticable improvement in low-rpm running.
Has anyone else had problems like this?
Many thanks.
I suspect it might be, which is revealing a poor charging circuit.zimm wrote:what state's the charging circuit in ?
is the current draw higher with the 4 coil's being fired as 2 pairs compared to having the original pair firing singly ?
